Need Help Removing Quasar OTR Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 01-03-2010, 11:23 AM   #1
Need help removing Quasar OTR Microwave
1992 Quasar Superwave
Model MQ1000W
I have removed the fan plate underneath. Then I removed 8 screws from underneath. Then 4 side screws and 2 top screws. There are no screws in the top or side cabinets. It looks to me like the unit is all one piece and there is no separate bracket. It also looks as if the unit was screwed in from the back of the wall?? The back opposite side of the wall is the dining room and I would rather not have to rip it apart but I will if have to.
Does anyone have any expeirinece in this?Any and all feedback would be greatly appreciated.
Stcrosby is offline   Reply With Quote
Old 01-03-2010, 11:25 AM   #2
you should be able to find install specs online
Old 01-03-2010, 12:35 PM   #3
firehawkmph's Avatar
Rewards Points: 1,798
Stcrosby,
I googled it but didn't come with much. Can you post a few pics of the unit. It's unusual for it not to be connected through the cabinet above. Some units have screws behind the front grill where the air recirculates from if it is a non-vented unit.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-03-2010, 02:06 PM   #4
After a little more digging I was able to find 1 hiden top screw and I was able to get the unit out. Thanks for your assistance.
Old 12-31-2012, 11:21 AM   #5
Removing Quasar Microwave
Just for the future record: I just removed a Quasar model MQSV115H - 1994. First remove top screws from cabinet above MW. Then slide horizontally straight out. There are hidden thin brackets that slide into the MW on the sides that hold it in place.
alkspa is offline   Reply With Quote
Removing a Sharp over the range microwave bcbowers Building & Construction 7 11-01-2010 06:10 PM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 04:47 AM
Removing a GE Profile space makerXL 1800 microwave cannoncj Appliances 4 12-03-2009 09:29 AM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
