Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-09-2012, 09:25 AM   #1
need help with homebuilt electric BBQ smoker
I'm building a BBQ smoker and I need a little help to get it finished safely.
I just basically built an insulated box, like a fridge. The dimensions are 20" X 20" X 55". I ordered some parts from an appliance parts distributor. I have a stovetop burner and a terminal block for it. I also have a basic oven thermostat to regulate the temp. I have 220 powering this setup, and I tested it and it works properly.
The problem is that the burner is 8" and I designed it to sit in the middle of the smoker's floor. If I use the plastic terminal block to connect the burner I'm afraid it will melt. Smoker temp will be 200-300 deg. F.
Can I solder high temp wire directly to the terminals on the burner? Or could I take the connectors out of the terminal block and power the burner without the block? If I did either of these two things could I insulate the connection with heat shrink or high temp tape?
mike oleary is offline   Reply With Quote
GFCI outlet & electric smoker aleciadooley Electrical 4 09-11-2011 01:07 PM
String trimmers - gas, corded electric, or battery electric - which one?? whataboutj Landscaping & Lawn Care 43 05-01-2010 10:25 AM
90 amp electric car charger! The future... Billy_Bob Electrical 16 02-16-2010 03:01 PM
