Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 05-18-2011, 11:54 AM   #1
p5200's Avatar
need help finding fuse for Oster Microwave
The fuse blown is rated 5KW 0.9 Amp. I've called locally in this small town and can't find anything unless I order. Does the fuse have to be rated 5KW? or can it be rated 250v. 0.9 amp. I assume it must be that high for surge reasons. It is an Oster model # OGG21401 Microwave I have verified the fuse is the only problem. Thanks for all help.
p5200 is offline   Reply With Quote
Old 05-18-2011, 12:50 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
where is that fuse located, it can not be for the power supply if its only .9 amps? BTW I have rarely seen any microwave fuse blow for no
reason.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-18-2011, 01:41 PM   #3
p5200's Avatar
It connects between a power transformer and the Capacitor Thanks!
Old 05-18-2011, 02:56 PM   #4
#1 HAWKEYE FAN
are you sure that is a fuse? can you post a pic
Old 05-18-2011, 09:21 PM   #5
p5200's Avatar
This is the setup I have all, I need is the 5kv. 900ma. glass fuse or something I could maybe find locally to substitute. Thanks!
http://www.aliexpress.com/fm-store/5...-6-5-40MM.html
big fuse problem randallatha Electrical 6 01-02-2011 12:07 PM
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 06:46 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
Microwave Fuse Replacement - Overbilling Glasnost Electrical 13 11-18-2007 10:27 PM
