Need Expert Advise On Washing Machine. - Appliances - DIY Chatroom Home Improvement Forum
Old 01-14-2012, 06:45 PM   #1
Rewards Points: 152
Need expert advise on washing machine.
My washing machine is having a problem draining the water at the final rinse. I have had this problem before and i disconnected the pump and found sediments in the pump which clogged the pump from draining the water.
This time, i unclogged the pump but still not draining.
I took apart the pump, the pump is connected directly with the shaft, shaft and pump is one solid piece, cant see the physical shaft,( motor is separte piece). When I the take out the pump(shaft) out of the coil windings, i can spin the pump wheel easily. Once i put the pump(shaft) back in the coil winding, the pump wheel doesnt spin easily.
Is the shaft out of alignment now? Do i buy a new pump piece?
humberguy is offline   Reply With Quote
Old 01-14-2012, 07:43 PM   #2
An old Tradesmen
Rewards Points: 7,816
Moved to Appliance forum.
Old 01-14-2012, 07:49 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
having trouble figuring out exactly what you mean by pump shaft, coil windings ect. What kind of machine and model do you have?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 10:51 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
