Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-27-2009, 07:05 PM   #1
natural gas to propane conversion
We bought a gas stove and coverted it to propane.I converted the regulater, installed the LP orfice spuds, adjusted the burner orfices and adjusted the air shutters. The problem is when I try to adjust the surface burners thier seems to be too much gas or pressure when trying to set the burners on high after adjusting the flame. I can only get the setting to about half way and the flame is at least 1 inch off the orfice ,if Itry turning up the burner more the burner blows out.Any help would be greatly apprciated.The stove is a GE Profile XL44 thanks,Brian
Brian U is offline   Reply With Quote
Old 09-28-2009, 12:36 PM   #2
DIY Hack
Mr Chips's Avatar
take a look here for some things to check
There is plenty of room for all God's creatures...
Right next to the mashed potatoes.
Mr Chips is offline   Reply With Quote
More On This Topic
Bamboo charcoal is a semi-porous substance with excellent absorption benefits. There have been many uses discovered for bamboo charcoal both in personal and home care. You can purchase bamboo charcoal at some health and nutrition stores or you can easily... Read More »
How to Remove Oven Parts
How to Remove Oven Parts by Expert Village
Hi, I'm Jennifer Cail. On behalf of Expert Village, I'm going to show you how to clean and maintain your oven. Our first step before we start cleaning our stove is to remove all of the removable parts. This will make it much easier to get at the parts... Read More »
Hi! This is Dave for the Big Easy Catering Company in Santa Barbara, California and expertvillage.com. We’re making jambalaya today, and I wanted to show you some of the equipment that you will need for a large quantity of people. However, you can... Read More »
Hi! On behalf of Expert Village my name is Andrea Spano and I'm going to show you how to make Ganache from my new book "Not Just Desserts." Okay. As you can see, the cream is boiling. I'm taking it off the flame. I'm shutting off the heat source... Read More »
Restoring an old stove is a big project. Refurbishing this appliance from scratch requires a lot of time and some expense. Learn about the internal workings of a stove and gain an understanding of the mechanics of a stove to facilitate the refurbishment. Read More »
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 04:57 PM
converting propane boiler to natural gas drewhart HVAC 25 01-15-2009 06:23 AM
williams direct-vent propane conversion leach HVAC 2 12-18-2008 02:51 PM
Propane to Natural conversion higgsfamily5 Appliances 5 11-06-2008 10:51 PM
oil burner to propane conversion mikevacarr HVAC 4 06-20-2008 11:38 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
