Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-13-2008, 06:14 AM   #1
Natural Gas to L.P conversion on stove.
I have a new G.E Hotpoint stove. When it was converted over to L.P. the oven won't adjust correctly. The burners are great and the broiler is good. The oven has about 1/2 inch of yellow flame on it. Any ideas why.
RobertS is offline   Reply With Quote
Old 02-13-2008, 03:17 PM   #2
Yellow flames means to much air.
Can you provide the model number of your range?
girltech is offline   Reply With Quote
Old 02-20-2008, 09:15 PM   #3
For the top burners, you had to replace orifices, right? For the oven, did you replace the gas orifice, or tighten the hood orifice until it stopped? If the hood orifice is not tightened enough, there may be too much gas, producing a yellow flame. The trick on tightening a brass hood orifice is to tighten it all the way, without breaking it! Adjust the air shutter to full open. If there is too much air for the correct amount of gas, you will have noisy, lifting blue flames. Adjust the air shutter a little.
Propane is a hydrocarbon. Yellow in a LPG flame will produce carbon (soot). The reason is: Too much gas, or too little air, or both. When converting appliances to propane, in general, the air shutter is opened fully or nearly so. (For Natural gas, 2/3 closed).
jimmyj555 - 28 years a gas man.
jimmyj555 is offline   Reply With Quote
Old 03-08-2008, 12:04 PM   #4
I just scored!(I think) on a Dacor gas cook top s6m3045 I t is for natural gas.
Can I convert to propane it or did I just throw money away?
bargainhunterkl is offline   Reply With Quote
Old 03-10-2008, 01:06 PM   #5
Master General ReEngineer
Bondo's Avatar
If you can get the orifices,..... Sure....
3 wire stove connection bgoldie Electrical 13 03-01-2011 01:29 PM
Stove Top wire capt2 Electrical 8 10-05-2007 02:41 PM
Gas stove top/oven conversion to combo range... Leikela Appliances 1 03-08-2007 07:16 PM
Coal Stove Hood Devil505 HVAC 1 12-06-2006 06:32 PM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 06:06 PM
