Nat. Gas Range Hook-up - Appliances - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 02:08 AM   #1
Nat. Gas range hook-up
Which side of compression hose is hooked up first?
Gord7 is offline   Reply With Quote
Old 03-26-2011, 09:21 AM   #2
I guess you mean the flex line? using an apporpriate length line- first install a shut off on the supply side. nipple out of that, then the flare nuts on both sides- using pipe dope or approved tape. with two wrenchs hook up either end of the line first. do not use any sealer on this flare fitting. check for leaks. if it's new construction don't run flex line through floor.
Jacques is offline   Reply With Quote
Drop in range versus self standing for narrow area sbrink Kitchen & Bath Remodeling 6 01-21-2011 11:17 AM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
Alternative to range hood fan Richo HVAC 2 04-11-2010 03:43 PM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 06:39 AM
3 Prong Range Hook up question tulsa442 Electrical 20 04-15-2008 10:58 PM
