My Washing Machine Is Leaking Oil - Appliances - DIY Chatroom Home Improvement Forum
Old 02-07-2014, 03:06 PM   #1
Rewards Points: 172
My washing machine is leaking oil
This is a Whirlpool LSQ 8000LQ3 bought in 2006.
Moved it for the first time in a LONG time and found what seems to be an oil spot about the size of a nickle. It is directly under the center of the washer.
Could a motor or gear box have a bad seal or.........?
Thank you
Cedrus is offline   Reply With Quote
Old 02-07-2014, 07:01 PM   #2
Rewards Points: 286
Thank you
Probably coming from the transmission. It's possible it could be a bad seal or loose bolt(s). If your handy, you can try and tightened the bolts and see if that helps. Wipe up the excess oil spot and diffinately keep an eye on it. If you notice more oil coming out, get it fixed as soon as possible. Once enough oil has drained out of the transmission it will lock up and fail. Just a thought.
jmon is online now   Reply With Quote
Old 03-20-2014, 08:58 AM   #3
Rewards Points: 172
A repairman came over and found a oil leak at a bottom seal. Said Whirlpool washers all do this and keep an eye on problem. I have a piece of cardboard under and look from time to time. It show a spot of oil occasionally, not every cycle.
He gave an estimate for repair P&L of $400 and said repair is better than any new machine.
So right now we will use it until something goes seriously wrong.
Old 03-20-2014, 10:33 AM   #4
Rewards Points: 286
Thanks for the update. Glad it worked out for you.
Increasing height of washing machine standpipe Agnikan Plumbing 1 06-03-2012 09:37 AM
Washing machine leaking sreed73 Plumbing 1 05-17-2011 06:51 PM
Washing Machine not working..? YellowCar Appliances 2 04-27-2011 08:42 PM
Washing Machine compression valve leaking...HELP! tmcguirk Plumbing 12 04-17-2008 08:16 AM
