Is My Washer Lid Switch Bad? - Appliances - DIY Chatroom Home Improvement Forum
Old 02-12-2011, 12:34 PM   #1
Rewards Points: 91
Is my washer lid switch bad?
Kenmore clothes washer runs fine until spin cycle. It starts to spin and then kicks off, then starts again and then off. Finally I put a big bottle of laundry soap on the lid by the switch and it runs fine.
I just wonder if before I change the switch should I check anything else like maybe an adjustment?
sofasurfer is offline   Reply With Quote
Old 02-12-2011, 08:08 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
yes, change it
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-13-2011, 12:32 PM   #3
Rewards Points: 530
If the door has a warp in it or the actuator is faulty, a new switch will not help.
Maybe check to see if the switch has worked loose, dropped, pushed in, whatever.
I like to cover the simple free things that can go wrong before spending money.
Old 02-13-2011, 12:49 PM   #4
Rewards Points: 91
Good advice. Thanks
Wiring in a 4-way Switch RickSene Electrical 6 05-13-2017 04:29 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 01:24 AM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 08:00 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 06:14 PM
