My Pilot Light Won't Light - Appliances - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 11:13 AM   #1
my pilot light won't light
Im holding down the button to light the pilot light but it won't light. Whay else can I do?
marcgab is offline   Reply With Quote
Old 02-04-2012, 01:19 PM   #2
If it wont stay lit, try tapping the gas valve with the handle if a screw driver. Failing that, replace the thermocouple or thermopile, whichever your appliance has. If it won't light at all, ensure your gas is on, or, of it has a piezo igniter, verify that it is sparking.
hvac benny is offline   Reply With Quote
Old 02-04-2012, 02:08 PM   #3
Exactally what are we talking about here ? I'm assuming a hot water heater ? If so there should be TWO buttons that you will press. 1 will be the gas value adjustment knob will need to be in the pilot position and you will need to press that button down to open gas valve. While holding that button in the DOWN position press the ignite/spark button . Once you see the flame continue holding down gas adjustment knob for30-90sec. Did it help?
acestarservices is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Williams NG furnace pilot light will not stay lit zBernie HVAC 1 12-04-2011 11:06 PM
single pole switch with pilot light tsc2011 Electrical 8 11-29-2011 08:50 AM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 08:49 AM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 06:16 PM
