My Fridge Is Leaking - Appliances - DIY Chatroom Home Improvement Forum
Old 07-18-2009, 02:27 PM   #1
My Fridge is leaking
Our fridge is about 10 years old and it works perfectly as it is intended. For the past week or two, however, we have 'consistently' found some "small puddles" under the fridge and I am wondering if it is a minor issue that can be fixed or should I plan a visit to a local Best buys? I pulled the unit away from the wall and cleaned the dust/crap as much as I could. I was also looking for a drain but I could not as someone suggested.
Thanks for the help in advance! Ed
eddie101 is offline   Reply With Quote
Old 07-18-2009, 10:11 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 126
Is it an old fridge? I remember our old fridge had this tray that had to be emptied every now and then.
Old 07-19-2009, 07:48 AM   #3
First look under the front behind the grille and see if you have an evap tray. It might be cracked. Second, is it equipped with ice maker or water dispenser. If so Check your connections
Chemist1961 is offline   Reply With Quote
Hotpoint freezer cool fridge too cool Maddyrosedad Appliances 1 02-19-2009 05:38 AM
freezer leaking into fridge - cannot locate drain hole pro_DIYer Appliances 5 12-31-2008 11:08 PM
leaking fridge door paxxxx Appliances 1 01-11-2008 01:45 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 09:55 AM
