My First Gas Cooktop Installation - Appliances - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 06:01 PM   #1
My first gas cooktop installation! HELP!!!!!
Hello guys,
what should I know before I disconnect my old GE white cooktop and connect a Bosch stainless cooktop? Is it as simple as
1) Turn the yellow handle counter-clockwise to turn off the gas
2) disconnect the old regulator at the base of the old cooktop
3) disconnect the old regulator from the gas pipe
4) connect the new regulator to the gas pipe and then to the new cooktop's base
5) connect electricity to the new cooktop
Please let me know if there are certain glues or other stuff that I need. I'm gonna attempt this on thursday.
thanks
Sam
emperor_black is offline   Reply With Quote
Old 03-08-2010, 06:10 PM   #2
the only trip to the store i see is if the new reg fitting to pipe is different size than old. if the connection is not a flared fitting and is threaded you will need pipe dope compatible for gas threads, you may be able to use teflon tape instead hopefully a gas person will confirm
The older I get the better I was
Old 03-09-2010, 08:14 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
You can us the proper teflon tape rated for gas. It is usually yellow in color.
Coastal South Carolina
Old 03-10-2010, 03:11 PM   #4
I got both the teflon and joint compound. Thanks!
Installation problem!!!
When I blow air from one side of the regulator, I can feel the air coming out the other side. So, regulator is fine, but there is no flame. Electrical seems to be fine since I can hear and see the sparks. But there is no flame!!
When I blow air at the underside of the cooktop where the regulator attaches, I cant feel air coming out of the nozzles. any clues? Or is the air coming out of the nozzles too small to be felt? thanks!!!
--Sam
Cooktop wiring upgrade Booron Electrical 7 12-08-2009 01:43 PM
Konecto Installation Tidbit jennydavis Flooring 9 01-06-2009 12:19 AM
jenn-air cooktop installation shayne Electrical 5 12-09-2008 05:23 PM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
