Is My Dishwasher Motor Frozen? It Just Humms - Appliances - DIY Chatroom Home Improvement Forum
Old 01-22-2014, 04:13 PM   #1
Rewards Points: 214
Is my Dishwasher motor frozen? It just humms
Hello All,
Our dishwasher began running very loud a few months ago but would still clean dishes fine. It however stopped working last night.
It will fill with water but instead of starting to wash, it just makes an electrical humming noise. I removed all the internal parts and found no debris. I also had the Parts House check the capacitor and they stated it was good. Therefore, at this time I would assume the motor has simply gone bad/froze up? Would this seem to be the most likely issue?
BTW, as noted: It will fill with water and it will drain if you press cancel. All of the digital button/lights appear to be working fine as well.
Any input would be appreciated.
Ralph
Ralph III is offline   Reply With Quote
Old 01-22-2014, 06:42 PM   #2
Rewards Points: 342
Could be a couple different things. Make and model would help. Thanks.
Go to link and type in your model number and click on repair help for dishwashers.
click here for link
jmon is offline   Reply With Quote
Old 01-22-2014, 07:46 PM   #3
Rewards Points: 214
I have a KitchenAid KUDK03CTSS2
The main pump/motor is model (8535759) or substitute (W10239404). I've since removed the motor/pump and I can rotate the impeller with a little resistance. It doesn't freely spin and I can hear a little grinding noise as I turn it though? It also seems not to rotate consistently, meaning it will rotate slightly harder at times or positions?
Ralph
Old 01-22-2014, 09:01 PM   #4
chitownken's Avatar
Rewards Points: 510
Could have some debris in the pump. Did you have a glass break in the dishwasher recently? Lose a small piece off of something you put in the dishwasher? Try turning the pump backwards while holding it upside down to see if you can dislodge something.
chitownken is offline   Reply With Quote
Old 01-22-2014, 09:05 PM   #5
Rewards Points: 14,294
http://www.repairclinic.com/RepairHe...se-KUDK03CTSS2
Old 01-22-2014, 10:26 PM   #6
Rewards Points: 214
Thanks for the input.
As noted, I've cleaned the screen and blade area from within. I then removed the pump motor itself with unit upside down and there is no debris.
It has to be the pump motor! That's what RepairClinic suggests as well.
*The inlet valve works fine, as it will fill with water.
*The drain pump works fine, as it drains fine with cancel.
*The instrument panel appears fully functional. In addition, it would not have had anything to do with the increased operational noise.
The pump motor will not run, it just humms. I'm not an appliance repair man but to me that indicates a bad capacitor or bad motor. The capacitor was tested good so it has to be the motor. The increased noise could have been a bearing going bad which finally failed.
So I will look to replace the motor.
Thanks for your efforts,
Ralph
Old 01-23-2014, 05:30 AM   #7
Rewards Points: 1,300
This makes it a bit confusing. If the pump runs on cancel then it is not bad. or does this machine have two drain pumps?
I would suspect that maybe the hum you hear is a solenoid not fully engaging allowing the next cycle to start
danpik is offline   Reply With Quote
Old 01-23-2014, 08:57 AM   #8
Rewards Points: 214
There is a separate drain pump and then a main pump motor. The water inlet valve allows the dishwasher to fill with water. If you press "cancel" the drain pump will then properly drain the water.
It just will not wash, which is the main pumps duty (circulating) but instead it just humms. The most obvious would be that the capacitor went bad which starts the main pump motor. The capacitor tested good however. The next possibility, as I see it, would then be a failed pump motor.
What "solenoid" are you referring to that might not be allowing it to cycle through? Irrespective, a solenoid wouldn't account for the significant increase in operation noise over the last month. So that would seem unlikely unless I've had something additional fail as well...
A main pump motor going bad however would make sense with the noise increase and then eventual failure. When I turn the motor tiny bits of rusted metal falls out, so I assume a bearing or such has failed. Anyhow, everything seems to point to that but I will find out soon when the new unit comes in.
Take care,
Ralph
The Following 2 Users Say Thank You to Ralph III For This Useful Post:
danpik (01-23-2014), jmon (01-23-2014)
Old 01-23-2014, 09:28 AM   #9
Rewards Points: 342
Let us know how everything works out for you. Thanks.
Old 01-23-2014, 02:21 PM   #10
Rewards Points: 1,010
Isn't anyone going to tell him the motor is humming because it doesn't know the words???
spaceman spif is offline   Reply With Quote
The Following User Says Thank You to spaceman spif For This Useful Post:
jmon (01-23-2014)
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 12:56 PM
Dishwasher powder instead of salt - Doh! Bottletops General DIY Discussions 0 03-03-2010 11:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
