My Central Vacuum Suction Works, But The Powerhead(sweeper) Does Not Turn On - Appliances - DIY Chatroom Home Improvement Forum
Old 04-17-2012, 02:45 PM   #1
My central vacuum suction works, but the powerhead(sweeper) does not turn on
My house is roughed in for a central vacuum system with 2 pins at each wallplate and 2 wires sticking out at the other end at the garage with a white plastic tube. I connected a Eureka Mega Boss central vacuum cannister which my friend gave me (after I have tested it, including the sweeper(powerhead) )as he upgraded. After installing the vacuum tubes to the cannister , I inserted the 2 wires into the mini-plug-ins at the cannister. When I plug in the hose at the wall plate and turn on the switch at the hose handle, the suction works but the powerhead does not turn on. I tried reversing the polarity of the 2 wires at the cannister but the problem remains the same. The power head (sweeper) is brand new and it is working when I tested it at my friend's place. What is wrong? Thanks very much
BGees is offline   Reply With Quote
Old 04-17-2012, 03:55 PM   #2
Rewards Points: 1,456
Electric beater brush?
ktkelly is offline   Reply With Quote
Old 04-17-2012, 04:03 PM   #3
Check for any switches or buttons on the power head itself and not just at the handle switch. Mine has a large push in button right on top of the powerhead
creeper is offline   Reply With Quote
Old 04-17-2012, 10:52 PM   #4
Registered User
Rewards Points: 5,216
Most units, two 18gauge wires are for activating only the vacuum motor for suction, to be hooked up at each remote door. Is the beater bar electric, as asked already, or run off the suction?
Gary
Old 04-18-2012, 05:36 AM   #5
OP said there is a dedicated handle switch.
Old 04-18-2012, 06:50 PM   #6
Registered User
Thanks, I see that. If no plug-in dedicated 110 for a power brush at each inlet, it works off the suction (much weaker). The slide switch on mine only activates the suction (including the power-head) turning the units motor on-off. No motor-head switch, older unit...Is your test house the exact same system?
Gary
Central heater works only when I help jump start the motor by turning it. stanlam HVAC 10 12-11-2012 06:24 PM
Central Vacuum Wiring Rough-In ebayhoey Electrical 2 07-10-2011 04:08 PM
central vacuum amba Electrical 1 03-13-2011 06:15 PM
problem with furnace will not turn on or works by itself tech2002 HVAC 3 12-29-2010 04:36 PM
My furnace works but my air conditioner will not turn on david143kat HVAC 1 06-29-2010 07:17 PM
