Moving Washer/dryer From Basement To 2nd Floor - Appliances - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 11:16 PM   #1
Question
Moving washer/dryer from basement to 2nd floor
So I'm wanting to move my front loading washer and dryer from the basement up to the 2nd floor where the bedrooms are at. I've read posts about people have zero problems with vibrations and tons of posts about people who have had problems with vibrations.
How feasible would it be to do this project? I was thinking I could build a cabinet to slide the washer and dryer into and top the cabinet with marble so that there is no room for it to vibrate. Is this something I'd be able to do on the existing floor or should I tear up the floor and add additional support beams?
DIY newbie is offline   Reply With Quote
Old 02-12-2010, 11:21 PM   #2
Rewards Points: 6,652
Personally, I would not do it. You have to come downstairs to exit, eat dinner, get the mail, so what is so hard about leaving it where it is?
Old 02-14-2010, 07:36 AM   #3
if you're determined to put it on the 2nd fl; talk to a contractor on how to strenghten floor. may only have to put down 1/2-5/8 plywood....some brands are prone to vibrating especialy when on pedestals. there are pads you can buy ie; 'SHAKE A WAY' to diminish it....keep in mind that front loaders, whether stacked or side by side, require the top to be removed for many different service repairs; so if you build it in you'll be in trouble WHEN it breaks.
Jacques is offline   Reply With Quote
Old 02-14-2010, 08:38 AM   #4
IMO:
#1 Some front loaders have unusual vibration and turbine noises that are different from regular washers
#2 Potential water damage from old hoses or loose connections can be your personal tsunami
#3 laundry that needs to be hung needs room to dry
#4 nothing is more solid than the concrete floor in the basement
aggreX is offline   Reply With Quote
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 05:58 PM
Basement Floor Buckelling catnkaboodle Remodeling 2 09-17-2008 09:16 AM
Need Help! Wet basement floor??? JamoDenver Building & Construction 5 01-11-2008 12:43 PM
leveling floor without moving joists slhfire Flooring 9 08-28-2006 08:58 PM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
