Moving Gas Dryer - Appliances - DIY Chatroom Home Improvement Forum
Old 06-28-2007, 08:34 PM   #1
Rewards Points: 43
moving gas dryer
hello. i'm remodeling a basement, and in order to make some room, i've decided to move the gas dryer to a spot in the basement where it seems it once used to be. looks like when it was moved to where it is now, they just capped off the supply line at the old location and left the old black pipe hanging. then a little ways back on the supply line, they tee'd off and put in some new pipe, sending it to the dryer's new location on the other side of the basement.
my question is:
is my work essentially limited to:
1)shutting off the gas
2)unhooking the supply line
3)capping it off, and
4)moving the dryer to the old location, hooking it back up to the old supply line?
there's already an electrical outlet and vent outlet in my new location, too, so i should be covered, right?
i've never worked on gas line before, but ive seen it done, and i've done a bit of plumbing so i know how to work with pipe.
thanks
sonofthetonsured is offline   Reply With Quote
Old 06-28-2007, 09:25 PM   #2
Eibwen
I would suggest getting a qualified person to come in and at least give you an estimate before you proceed. If all of the pipe is in place it shouldnt cost that much for them to do the hookups for the gas and test it. As you said you have never worked on a gas line before. Its something you want to make sure is done right the first time.
Sammy is offline   Reply With Quote
Old 06-29-2007, 09:26 AM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Sounds like you are good to go. Make sure you know how to check for leaks and make sure your vent is not obstructed.
Brik is offline   Reply With Quote
Old 06-29-2007, 01:59 PM   #4
Is this gas LPG or Natural Gas. PLEASE make sure you shut off the supply line before disconnecting anything.
Liquid Propane Gas is heavier than the air and will find the lowest level in you basement.
I would recommend having a professional come in, how much could they charge, and for what an hour. Just have everything prepared ahead of time.
This is not something to mess around with. I am a also a fireman, there have been more than enough house explosions do to gas leaks. The explosion will separate your house from your foundation!!!
rolldodge is offline   Reply With Quote
Old 06-30-2007, 08:57 PM   #5
Rewards Points: 43
hey guys. got it all hooked up, and not an explosion to speak of i sprayed it all down with soapy water, too, to check for leaks, just so yz kno. thanks for the coaching & take it easy
Old 07-01-2007, 04:50 PM   #6
Contractor
Dan101's Avatar
Glad you got it all hooked up. Gas lines can work loose. Just to be safe, I would suggest checking it with soapy water at least 3 or 4 more times in the next week. Never hurts to be tooo careful.!
Dan101
Owner
J.& D. Remodeling
Chicago, IL
Dan101 is offline   Reply With Quote
Old 07-01-2007, 10:49 PM   #7
Rewards Points: 43
i will do so. thanks for the tip, dan
Old 07-03-2007, 07:28 PM   #8
Rewards Points: 43
smell gas during first run
hey everyone. everything went perfectly, checked the connections thrice, and all looks good. however, when running the dryer for the first time after moving it, i smelled gas. so, i shut off the dryer, shut the valve on the supply, and shut the main. after a few minutes, the smell dispersed, at which point turned on the main and the supply to the dryer and again sprayed all my connections (and some i didn't even touch) with soapy water. nothin. i figured maybe in moving the dryer, something went wrong with the ignition in the dryer, so that when it was running, gas was pumping through, unlit. i found the ignition underneath, which was a glow plug. i turned on the dryer, and everything seemed to be in working order- the glow plug would glow, the gas would click on, and the dryer would dry(in intermittent cycles) -no smell, either. i did this for quite awhile, on my hands and knees smelling everywhere, and watching for something to malfunction under the dryer, but to no avail. i talked to the guy across the street who is a master plumber (i didn't see any credentials, but the guy has always seemed to be quite knowledgeable, regardless). he said that is not out of the ordinary to get a gas smell on the very first run after you move a dryer, but definitely cautioned that if we smell it again to get him or someone in there to look at it.
my question- is this at all normal, or should i be worried. again, i quadruple-checked all my connections, and i can't even really see the problem being a connection what with the quick onset of the smell, and then its quick dispersion after shutting everything down. and i have run the dryer since, and everything went smooth.
Old 07-03-2007, 08:45 PM   #9
Contractor
Dan101's Avatar
I always smell gas the first time when I hook an appliance up.
My theory...and this could be completely wrong so please take it at face value. Many appliance valves contain a diapraghm which will hold a small amount of gas when they are disconnected. They also contain a vent that will release trapped gas. when they are reconnected and pressure resets the diapraghm. Please keep in mind that I have replaced thousands of valves on HVAC furnace units but have much less experience with appliance valves.
Please continue to keep a close eye on it.
Dan101
Owner
J.& D. Remodeling
Chicago, IL
Old 07-07-2007, 01:34 AM   #10
Rewards Points: 382
Some gas companies will check for a gas leak with their sniffer. Their sniffer is more expensive and much more sensitive to gas leaks than your nose or soap solution.
fireguy
fireguy is offline   Reply With Quote
Old 07-07-2007, 11:01 AM   #11
Deplorable Electrician
MechanicalDVR's Avatar
Rewards Points: 81
If you didn't purge the air out of the line before you made the dryer connection, there would be an air gas mix in the line to the burner that wouldn't ignite the same as if it were raw gas, it would take much longer. A furnace will lock out before lighting after three tries, an appliance will just keep trying til it lights. So you will smell gas on a new light off from a stove or dryer.
MechanicalDVR is offline   Reply With Quote
Old 07-07-2007, 06:52 PM   #12
Rewards Points: 43
yeah i think you're right. i have run the dryer quite a few times now with no problems, and after asking around i've gotten the same or similar explanations. i would be more worried if it was anomalous to my situation, so it's good to find that it seems to be normal. thanks again, everyone, for the advice
~jim
Old 07-07-2007, 10:56 PM   #13
Rewards Points: 81
Anytime, your welcome
Electric Dryer wiring/plug question SpaceCrawler Electrical 6 08-26-2008 04:33 PM
Problem with ELECTRIC DRYER plugs SpaceCrawler Appliances 6 06-03-2007 10:21 AM
Moving washer/ dryer from 1st to 2nd floor sebastien1 Remodeling 33 11-08-2006 09:31 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 09:16 PM
wiring for a dryer irish_hood Electrical 4 01-11-2006 01:27 PM
