Moving Electric Range - Appliances - DIY Chatroom Home Improvement Forum
Old 01-30-2011, 09:40 AM   #1
Moving electric range
I would like to be able to move my electric range any time i want to clean. Do they make casters on a frame for this? I haven't been able to locate anything like this.
dwolin is offline   Reply With Quote
Old 01-30-2011, 10:41 AM   #2
Experienced
Jackofall1's Avatar
I have not seen anything like you are thinking, but, you could replace the leveling pads with casters, allowing the stove to more easily be removed from the cabinets.
http://wthight.thomasnet.com/categor...FUVqKgodMg0l0g
Old 01-30-2011, 03:04 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
just a bad ideal in my opinion, if you want to move your stove get some of them furniture glides and put them under the legs.
hardwareman is offline   Reply With Quote
Old 01-30-2011, 09:45 PM   #4
Rewards Points: 530
My exact thought. Or may some small pieces of carpet.
The slide work pretty well for what they are designed for. The ones I have have a plastic bottom. If you have finished wood floors, you may want to just cut some scrap carpet squares, or find some slides with a soft bottom.
Old 01-30-2011, 09:51 PM   #5
I agree with hardwareman. I placed our ~400 lb gas range on sliders in case I ever need to service it and it works great over our cork floor.
VIPlumber is offline   Reply With Quote
Old 01-30-2011, 11:48 PM   #6
Registered User
Rewards Points: 526
Remember to dis-connect the "anti-tip" safety feature first, there to stop a tip over forward when the turkey is checked on....
Gary
Old 01-31-2011, 06:41 AM   #7
There's some dangerous/crazy ideas on the inner-net and this is one of them..but it's good it was posted so others will learn..like GBR said; this unit needs anti-tip bracket or tie-down for safety..
Jacques is offline   Reply With Quote
Old 01-31-2011, 07:08 PM   #8
Rewards Points: 530
Casters on a stove seems like a bad idea to me, unless....maybe some type of locking casters.
Ever know anyone that was burned from spilling liquid from a stove when they were very small? I have known two this happened to while very small. One guy's face. A girls back. That was....shocking.
Anyway, I thin they may have pulled something down from the stove. The point is I would want my stove to be fairly stationary to avoid some bumping it to hard and getting injured with hot food or drink.
I think the glides with tie downs is a good idea.
Replacing a 30" Electric Drop-in Range SLC3271 Appliances 5 06-10-2014 09:22 PM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 07:48 AM
Converting Gas Range with pilot lights to electric start gas range waterhead Electrical 5 01-02-2010 07:16 PM
Had a new electric range installed in my apartment - does this sound right? SAABturboDRIVR Electrical 15 01-02-2010 05:39 AM
install Electric range top JBH Electrical 7 01-18-2009 05:32 PM
