Moving The Cable Jack - Appliances - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 06-03-2016, 08:35 AM   #1
Rewards Points: 97
Moving the cable jack
Not sure where I should place this thread (here or electrical?) but here it goes.
In our new house we have a cable jack on the east wall of the living room. How do we move it to the west wall easily?
I'm trying to avoid cutting holes in the ceiling or ripping off carpet, etc. There is nothing connecting the west wall to the exterior walls. So I can't run a cable along the baseboards.
Is there a device where I can plug the cable jack in and broadcast to another jack on the opposite wall? What's it called? Anyone use one of these?
Thanks!
edta1 is offline   Reply With Quote
Old 06-03-2016, 11:30 AM   #2
Rewards Points: 2,794
Re: Moving the cable jack
Call your cable company to move this.
In my area the cable company gets irate when anyone other than their technician touches their cable.
Most cable companies will rent you a WIRELESS connection also, to send the signal to another place in your home.
ED
de-nagorg is offline   Reply With Quote
Old 06-03-2016, 12:08 PM   #3
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
If you don't want to drill holes yourself, call the cable company. They usually charge a small amount to install a new cable outlet/jack.
The way to do it is to go below (basement) or above (attic) the wall and drill directly through into the wall. Then fish a cable through the hole to the existing jack location and install a splitter. Now you have an active cable run. Find the wall you want your new jack, cut a hole for the jack location and again fish the wire from the basement/attic to the hole where you are installing the new outlet.
If you don't have access above or below the room, this project will be more complicated and you're probably best served by renting a wireless cable box.
hyunelan2 is offline   Reply With Quote
Old 06-03-2016, 12:22 PM   #4
Rewards Points: 97
YUP. And that's the problem. We are on a slab basement. So we can't go down. Upstairs is a bedroom, not an attic. Other option would be to pop holes in our living room ceiling and run a cable? That or go wireless.
We don't plan on getting cable TV. We want to use the traditional fishbone antennae.
Old 06-03-2016, 05:00 PM   #5
Tizzer's Avatar
Rewards Points: 466
Around here, Comcast restrings coaxial cable along the outside of the home then bores a hole through. Charge a small fee I think. Most of the time they'll send a self- install kit that you do yourself.
Or you can install the wireless modem on the east wall and live with it.
Tizzer is offline   Reply With Quote
Old 06-03-2016, 06:22 PM   #6
KarenStein's Avatar
Rewards Points: 426
Just a thought .... but will "Chromecast" do this?
Chromecats is a $35 gizmo that lets your computer 'broadcast' to your TV. I get my internet through the cable company. So ... maybe the geeks have the answer.
I'd visit BestBuy and ask the folks there ...
KarenStein is offline   Reply With Quote
Old 06-09-2016, 09:53 AM   #7
hyunelan2's Avatar
Rewards Points: 692
If you just need an antenna on the TV, put a single antenna behind the TV. There are plenty of hidden models out there. Don't even mess with running wires back to the main house antenna - unless you are extremely rural and need a SETI-sized array to get a signal.
Old 06-09-2016, 11:14 AM   #8
Rewards Points: 97
This might be an option. I just question how good they are. I don't think I've ever found one that picks up signals as well as the outdoor fishbone type.
I am in the suburb of Chicago. Not living in a high-rise downtown. Definitely a ways away from Willis Tower.
Old 06-09-2016, 12:17 PM   #9
Rewards Points: 74
Do you have carpet or hardwood floors?
bondra76 is offline   Reply With Quote
Old 06-09-2016, 12:58 PM   #10
Rewards Points: 97
Its carpet.
Old 06-09-2016, 06:49 PM   #11
KarenStein's Avatar
Rewards Points: 426
Fishbone antenna?
I thought all TV went digital in the 90's, so the old TV's and antennae became completely useless. Am I wrong?
"Digital" TV uses a different type of antenna. New TV's come 'digital ready.' More and more, the cable company is becoming a 'must' ... for cable, regular TV, internet access, and house phone as well.
"Dish TV" is basically cable by way of a satellite, while 'Quadravision" was a digital transmission of cable TV.
Personally? I stopped using ordinary TV -regular and cable- long ago. Whatever programming I want is available over the internet.
Old 06-09-2016, 07:03 PM   #12
Rewards Points: 1,484
This should do the job for you.
https://www.amazon.com/ClearStream-E...g=thewire06-20
It's one of the top rated indoor antennas.
No, I have noting to do with that company, and it may not do the job, but in your situation, it might be the best route to try.
Since you're not going to get cable, the cable company would very doubfully be interested in "helping you out" in any manner. Besides, most do really bad work.
ktkelly is offline   Reply With Quote
Old 06-12-2016, 11:13 AM   #13
hyunelan2's Avatar
Rewards Points: 692
Originally Posted by KarenStein View Post
Fishbone antenna?
This is mostly incorrect. An antenna is an antenna. Being an "HDTV" antenna is mainly a marketing gimmick. What has changed is the technology to decode the signal, which is inside the TV. If you have a TV from 1995, no antenna is going to work for you, and you'll need a digital decoder.
I am about 45 miles outside of Chicago. I have a large antenna I put in the attic of the garage, which does no better than the small antenna I have for a distant TV. The big difference maker is to put a signal amplifier on the antenna. Most decent antennas come with this, otherwise you can purchase it separately. Those make a much bigger difference than a different antenna from my experience.
The "Moho Leaf" antenna is a very highly rated antenna, and comes designed for a variety of ranges from 30, 50, 60 miles IIRC.
Old 06-20-2016, 12:48 PM   #14
Rewards Points: 22
Thumbs up
I couldn't agree more.....I dumped cable TV and now have a wire that splits into a "V" for an antenna and get about 30 channels. This works better than the "digital" antenna I bought (but I do use an amplifier)>
Sub
subbuilder is offline   Reply With Quote
Old 06-20-2016, 01:30 PM   #15
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
as hyun correctly stated, digital, analog, HDTV...what ever....an antenna is an antenna. They have a specific frequency range they work in. If you have an old UHF/VHF antenna, it will work just fine. Though I would suggest upgrading your coax to RG6.
We have been using OTA for years. The wife and kids spend a whole lot less time parked in front of the TV watching garbage. If there is something we really want to watch, it's DVD, Redbox or Netflix.
Or, the boys and I get out the chess board and have a friendly game....though, they are not so friendly now. My 12 year old is starting to kick my a$$.
sleepyg likes this.
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 12:35 AM
Adding phone jack simbey1982 Electrical 22 01-17-2012 04:40 PM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 Electrical 18 10-03-2009 10:20 PM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 06:55 AM
Installing a new phone jack. Which wiring to use for only 6ft? Help! romo218 General DIY Discussions 2 06-17-2009 04:56 PM
