Mounting A TV When Studs Are Close To 40 Inches Apart! - Appliances - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 04:38 PM   #1
Exclamation
Mounting a TV when studs are close to 40 inches apart!
Hi all!
We bought a wall mount for our 40 inch TV thinking the studs would be within the standard of 16-24 inches apart. However, when we finally got our hands on a stud finder, they are close to 40 inches apart! How in the world do we mount the TV now?
Thanks!
maestro2012 is offline   Reply With Quote
Old 03-10-2012, 08:36 PM   #2
Missouri Bound's Avatar
Hmm. First thought is that your stud finder doesn't work. What type of wall is it, drywall, paneling, wood? Need a bunch more information to advise you properly.
Do you want it your way or the right way?
Old 03-10-2012, 10:56 PM   #3
The wall is a dry wall and we don't think the stud finder is broken we checked another wall and it wasnt the same.
Old 03-10-2012, 11:02 PM   #4
Rewards Points: 12,792
Is it a plaster wall?
Look close at the wall for marks where there was screw holes covered with drywall mud.
Bore a 3" hole with a hole saw right where your going to install the mount. Then you could reach in and feel for the studs. Geet the plug to do the repair.
PaliBob (03-13-2012)
Old 03-10-2012, 11:20 PM   #5
Busy DIYer
picflight's Avatar
Rewards Points: 150
There are studs back there, you just need to locate them. I recently mounted a tv, it took drilling some pilot holes to find the exact location of the studs.
I first mark the stud near an outlet on the wall, I surely know it is there. Then measure 16" to my location, tap wall, use stud finder and finally drill pilot holes. I have old thick walls, so wasn't easy for me to firmly identify studs with stud finder.
picflight is offline   Reply With Quote
Tags
apartment wall , mount , studs , television
Mounting huge TV+sound bar above TV with down&out mount djgrant Building & Construction 6 10-05-2011 02:55 AM
Mounting a mirror on off-center studs? SteveB87 Remodeling 4 09-29-2011 08:42 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
Cripple studs below a header mercy Building & Construction 3 01-20-2010 04:20 PM
Mounting LCD but need to come up with "space" keepsmilin456 Home Theater 2 10-22-2007 04:55 PM
