-   -   Mounting a TV when studs are close to 40 inches apart! (http://www.diychatroom.com/f47/mounting-tv-when-studs-close-40-inches-apart-136611/)
maestro2012 03-10-2012 03:38 PM
Hi all!
We bought a wall mount for our 40 inch TV thinking the studs would be within the standard of 16-24 inches apart. However, when we finally got our hands on a stud finder, they are close to 40 inches apart! How in the world do we mount the TV now?
Thanks!
Missouri Bound 03-10-2012 07:36 PM
Hmm. First thought is that your stud finder doesn't work. What type of wall is it, drywall, paneling, wood? Need a bunch more information to advise you properly.:yes:
maestro2012 03-10-2012 09:56 PM
The wall is a dry wall and we don't think the stud finder is broken we checked another wall and it wasnt the same.
joecaption 03-10-2012 10:02 PM
Is it a plaster wall?
Look close at the wall for marks where there was screw holes covered with drywall mud.
Bore a 3" hole with a hole saw right where your going to install the mount. Then you could reach in and feel for the studs. Geet the plug to do the repair.
picflight 03-10-2012 10:20 PM
There are studs back there, you just need to locate them. I recently mounted a tv, it took drilling some pilot holes to find the exact location of the studs.
I first mark the stud near an outlet on the wall, I surely know it is there. Then measure 16" to my location, tap wall, use stud finder and finally drill pilot holes. I have old thick walls, so wasn't easy for me to firmly identify studs with stud finder.
