Mounting Receptacle Box For Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 04-21-2016, 09:46 PM   #1
jkk
Rewards Points: 233
Mounting receptacle box for microwave
We've cut a hole in the back of the cabinet that holds the microwave. There is 1.25" from the front of the cabinet back to the backside of the drywall. That's too much for the tabs on an old work box.
How do we attach the box? Get one with ears that accommodate a screw?
jkk is online now   Reply With Quote
Old 04-22-2016, 07:48 AM   #2
Rewards Points: 3,707
Re: Mounting receptacle box for microwave
Buy one of the new work boxes that are adjustable even after install. They move forward or backward when you turn a screw.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is online now   Reply With Quote
Old 04-22-2016, 07:53 AM   #3
Rewards Points: 12,790
Use longer screws.
Old 04-23-2016, 08:55 AM   #4
I made the assumption that your image showed an oversize hole. Now I think it might be a scale issue. So adding to my comments.
The new stock of blue old work boxes at Lowes are slightly redesigned and feature 4 usable screw holes on the lip in addition to the swing arms. 4 #6 x 5/8 pan head sheet metal screws will can secure the box to the cabinet back. This is the way to old Raco metal boxes with ears were always installed.
I know it works because I did it yesterday.
Colbyt
Old 04-23-2016, 07:42 PM   #5
jkk
Rewards Points: 233
That's exactly what we did last night except we used screws left over from metal studs. Worked out great.
Thank you for your replies.
connecting 30 amp receptacle to 40 amp breaker, Please Help dientho Electrical 3 05-11-2015 01:50 PM
Replacing receptacle, ground and neutral are connected NotAPlumber123 Electrical 6 04-29-2015 04:37 AM
Using bathroom branch to add receptacle in hall BrandonC_1972 Electrical 5 03-28-2015 08:03 PM
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 02:18 PM
Wiring a receptacle for a lift station hydrogeo99 Electrical 4 08-18-2010 02:04 AM
