Motor Amps - Appliances - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 08:09 AM   #1
jburd964's Avatar
Rewards Points: 166
Motor Amps
How can I tell the amps need of this 5 hp motor?
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 01-22-2013, 08:12 AM   #2
FLA. full load amps. This is the normal load and startup can be much more such as SLA or LRA on some data plates
64pvolvo1800 is offline   Reply With Quote
The Following User Says Thank You to 64pvolvo1800 For This Useful Post:
jburd964 (01-22-2013)
Old 01-22-2013, 08:18 AM   #3
jburd964's Avatar
Rewards Points: 166
Guess I may have to contact manufacturer.
Old 01-22-2013, 08:21 AM   #4
Rewards Points: 472
doesn't it say FLA-20.0 that is what you are asking ?
del schisler is offline   Reply With Quote
Old 01-22-2013, 08:39 AM   #5
jburd964's Avatar
Rewards Points: 166
I'm thinking there should be a surge amp rating for start up.
Old 01-22-2013, 09:09 AM   #6
Figure 3-5 times rated for instantaneous startup. I'd use a 30 and 10gauge.
Old 01-22-2013, 09:18 AM   #7
jburd964's Avatar
Rewards Points: 166
I'm confused 3/5 x 20 amps = 60/100 ???
Old 01-22-2013, 09:21 AM   #8
True, the momentary will peak that high but you size it for running amps. The breaker is inverse time so it will allow a brief surge. The higher, the quicker it pops.
Tags
amps , electric motor
