-   -   Motor Amps (http://www.diychatroom.com/f47/motor-amps-169794/)
jburd964 01-22-2013 08:09 AM
Motor Amps
1 Attachment(s)
How can I tell the amps need of this 5 hp motor?
64pvolvo1800 01-22-2013 08:12 AM
FLA. full load amps. This is the normal load and startup can be much more such as SLA or LRA on some data plates
jburd964 01-22-2013 08:18 AM
Guess I may have to contact manufacturer.
del schisler 01-22-2013 08:21 AM
doesn't it say FLA-20.0 that is what you are asking ?
jburd964 01-22-2013 08:39 AM
I'm thinking there should be a surge amp rating for start up.
64pvolvo1800 01-22-2013 09:09 AM
Figure 3-5 times rated for instantaneous startup. I'd use a 30 and 10gauge.
jburd964 01-22-2013 09:18 AM
I'm confused 3/5 x 20 amps = 60/100 ???
64pvolvo1800 01-22-2013 09:21 AM
True, the momentary will peak that high but you size it for running amps. The breaker is inverse time so it will allow a brief surge. The higher, the quicker it pops.
