Most Efficiant Use Of Dehumidifier - Appliances - DIY Chatroom Home Improvement Forum
Old 11-25-2009, 07:15 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Most efficiant use of dehumidifier
Say I want to dehumidify a certain area what is best thing to do, face the unit so it blows towards that area, or face it so it sucks the air from that area? My gut feeling tells me I should have it suck the air out of the area. If I make it push the conditioned air it's only going to push the humid air somewhere else instead of dehumidifying it. Am I correct?
Old 11-25-2009, 08:55 PM   #2
Ideal is pulling the air in from the area that needs to be dehumidified
Exhaust is then sent outside in perfect setup
Old 11-25-2009, 10:01 PM   #3
Wire Chewer
Rewards Points: 90
Cool that's what I figured.
Old 11-28-2009, 10:01 PM   #4
humid air moves toward non humid air.
so really it shouldn't matter where it is placed, it should work.
rvegab00 is offline   Reply With Quote
Old 11-28-2009, 10:32 PM   #5
Where the warmer air is directed can make a difference
If the area continues to get warmer then more moisture will condense
My basement (unheated) is driest in the cold winter
I'd like to be able to vent the air outside, but hard to do with cement walls
And I don't want to cut into the rim joist
Overall if the heat is going into an enclosed space then it won't matter
But moving the air around via the exhaust can have an effect
If placed in a corner you won't get the best air movement & effect
In this case one area (crawl space) may be more damp
So you want to pull air from that area IMO
No expert...just based on my own basement & moving them around
Where to place dehumidifier? griff531 HVAC 0 10-24-2009 01:50 PM
Humidifier and dehumidifier on furnace loadie HVAC 2 12-07-2008 03:16 PM
Can I do this w/a dehumidifier? famdog Plumbing 7 10-31-2008 09:53 AM
dehumidifier INSTEAD of crawl space vents DangerMouse Building & Construction 29 07-29-2008 12:55 PM
Dehumidifier install in basement? gone_fishing Remodeling 3 03-09-2008 07:25 PM
