Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-18-2006, 10:48 PM   #1
Exclamation
mini fridge thermostat problems
I have a Sanyo SR-4910 compact refridgerator that seems to have a thermostat problem. The temperature control goes from min-5, I have had it set on 2 and it is freezing my beer! I have now turned it down even more, but I am wondering if the thermostat is broken or if something else is going on? Any advice? Would it be an easy fix that I can do?
furniture_guy is offline   Reply With Quote
Old 12-19-2006, 07:55 AM   #2
jeff1's Avatar
Hi,
Make sure the capillary tube from the control that attaches to the evaporator in the back is not loose/mounting bracket is not broken/off completely...failing that, probably new control time.
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Are you having ice problems? Grumpy Roofing 27 02-17-2008 04:51 PM
Freezer leaking into Fridge? jc2709 Appliances 1 05-23-2007 10:55 AM
Noma Thermostat vs Old Thermostat diywoman Electrical 2 01-04-2007 02:02 PM
Fridge not cooling - evap fan? oppiecat Appliances 3 12-06-2006 07:46 AM
