Min Clearance Between Gas Stove And Wooden Cabintry Above - Appliances - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 03:25 PM   #1
Min clearance between Gas stove and wooden cabintry above
I've got a gas stove, am removing the microhood and replacing with regular hood vent fan that will be enclosed in matching wooden cabinetry. What is the minimum distance required between the stove top and the bottom of the wood surround for the hood vent?
dickensonwilson is offline   Reply With Quote
Old 02-12-2012, 04:10 PM   #2
Rewards Points: 14,010
18" is the min.
Old 02-12-2012, 07:11 PM   #3
Code here is 30"; 24" if the combustible material is protected by insulating millboard and sheet metal or; the rating plate specifies otherwise.
hvac benny is offline   Reply With Quote
The Following User Says Thank You to hvac benny For This Useful Post:
VIPlumber (02-12-2012)
