Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 07-13-2012, 11:20 PM   #1
Millivolts Using A Voltage Meter (Tester)
What would cause a low millivolt reading (with a millivolt/voltage tester) at a gas control valve?
Needtolearn is offline   Reply With Quote
Old 07-13-2012, 11:24 PM   #2
Ash on the thermopile/thermocouple. Sometimes they just burn out from the heat. Could be improperly set (flame needs to surround about 3/8 of the end, this can be double checked with adjustment)
Protocol. is offline   Reply With Quote
Old 07-14-2012, 08:06 AM   #3
It was a dark and stormy
Yoyizit's Avatar
Bad connection between the valve and the 'couple?
Short circuit in the valve?
You can pretty well simulate a 'couple or 'pile with a 1.5v battery and two properly chosen resistors. E.g., for a 750 mV 'pile with an internal resistance of 2.9 ohms, use two 5.6 ohm resistors.
Voltage tester Jed54 Electrical 6 10-30-2012 02:04 AM
Need recommendation of non-contact voltage tester miamicuse Electrical 6 05-22-2012 05:33 PM
Pen tester false-positive? campbesh Electrical 3 03-06-2011 12:11 PM
New clamp meter question Chevyman30571 Electrical 18 02-22-2010 12:35 AM
Frozen water meter stubborn1 Plumbing 5 01-26-2009 07:35 AM
