-   -   Millivolts Using A Voltage Meter (Tester) (http://www.diychatroom.com/f47/millivolts-using-voltage-meter-tester-150169/)
Needtolearn 07-13-2012 10:20 PM
What would cause a low millivolt reading (with a millivolt/voltage tester) at a gas control valve?
Protocol. 07-13-2012 10:24 PM
Ash on the thermopile/thermocouple. Sometimes they just burn out from the heat. Could be improperly set (flame needs to surround about 3/8 of the end, this can be double checked with adjustment)
Yoyizit 07-14-2012 07:06 AM
Bad connection between the valve and the 'couple?
Short circuit in the valve?
You can pretty well simulate a 'couple or 'pile with a 1.5v battery and two properly chosen resistors. E.g., for a 750 mV 'pile with an internal resistance of 2.9 ohms, use two 5.6 ohm resistors.
