Microwaves: Over The Oven Vs Built In - Appliances - DIY Chatroom Home Improvement Forum
Old 07-30-2009, 02:30 PM   #1
Microwaves: Over the oven vs built in
What is the difference between an over the oven microwave and a build in microwave other than the "range hood" on the over the oven?
I am putting in a range hood over the stove and was hoping to move the existing over the oven microwave to a built-in cabinet. Would that cause any problems?
A for Effort is offline   Reply With Quote
Old 07-30-2009, 05:14 PM   #2
motivator
Speedball's Avatar
I personally find the over the range microwave too high for me and I'm 5'11"
Otherwise a built in microwave can be built in at any height you wish.
Hope this helps.
............Enjoy...Pat
Speedball is offline   Reply With Quote
Old 07-30-2009, 05:32 PM   #3
There is a min height clearance over a stove
Anywhere else you can put it at any height
We bought a Reg microwave as it was a lot less $$ then an over the stove
The over the stove models are made 30' wide to match the stove
A stand alone model (ours) is 23" wide
The microwave can't be connected to the kitchen small appliance circuits unless it is a plug in/counter top model
A lot of the over the stove units have a dedicated circuit
Old 07-30-2009, 05:39 PM   #4
I appreciate your responses. My question is more if it is possible to put an over the oven microwave in a cabinet.
I have an existing over the oven microwave that I need to move because I am putting in a traditional hood. I didn't know if anything about the microwave vents the heat it produces would prevent it from safely being able to go in a cabinet.
Old 07-30-2009, 09:06 PM   #5
Idiot Emeritus
Rewards Points: 1,492
If the microwave ever fails, it'll be a lot easier to repair/replace one that isn't built-in.
Rob
micromind is offline   Reply With Quote
Old 07-30-2009, 09:10 PM   #6
Not if you provide proper ventilation.
Old 07-30-2009, 09:13 PM   #7
Mfg info should list clearances needed
Old 08-22-2009, 09:24 AM   #8
..... also if you build this in you'll be stuck with the same size constraints if you have to replace it. and the OTR m/o are more $. better to buy a $49/99 m/o that fits your needs.
Jacques is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Replacing Electric Built In Oven handygirl37 Appliances 2 09-09-2008 09:38 PM
Replacing countertop stove and built in oven becky3501 Carpentry 9 06-27-2008 09:41 PM
built under oven as a built in one? helen30 General DIY Discussions 3 01-27-2008 04:15 PM
