Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-30-2007, 08:47 PM   #1
Ummmm...
Shpigford's Avatar
Is a microwave wall mount necessary?
We just got a new over-the-range microwave and I'm curious if the wall-mount is really necessary.
I hesitate to do it mainly because it means I have to drill into our tile backsplash...which is obviously a bit more risky than drywall.
The microwave will be bolted at the top to our cabinets and, from what I understand, those bolts are what actually holds all the weight and the wall-mount at the bottom is just to keep the microwave from tilting/shifting when you open/close the door.
What I'm debating on doing is using something like a thin piece of condensed foam (think some like foam core board) with an extremely sticky layer on it and basically just "stick" the bottom/back of the microwave to the tile.
Sounds pretty rigged, but I'm just really hesitant to drill in our new tile.
Any ideas/suggestions?
Shpigford is offline   Reply With Quote
Old 12-01-2007, 07:09 AM   #2
You have it backwards. The wall mount holds the weight. The bolts are for keeping it from tilting and do contribute to holding a bit a weight.
Follow the mounting procedures and locate and install the mounting frame onto the studs. There is a special drill bit for drilling through ceramic tile.
Don't even try to mount it in an area of the wall that does not have a stud behind it. It won't last.
rjordan392 is offline   Reply With Quote
Old 12-01-2007, 07:22 AM   #3
Remodeler
MinConst's Avatar
The wall bracket is DEFINITELY needed. As stated it holds the majority of the weight and needs to have at least one screw into a stud.
Minichillo's Construction
I will never leave you hanging!
MinConst is offline   Reply With Quote
Old 12-03-2007, 09:44 AM   #4
Seasoned Noob
yep, just to reiterate, the wall mount is necessary. The wall mount is thin and seemingly flimsy but when you mount it flush against the wall it becomes much more substantial and bears most of the weight of hte appliance
hubbard53 is offline   Reply With Quote
Old 12-03-2007, 11:03 AM   #5
OP...
As Sir Charles would say .... "You just made my FIVE".....
JGarth is offline   Reply With Quote
Old 12-03-2007, 02:51 PM   #6
Long-Time DIYer
Mike Swearingen's Avatar
Shpigford,
To drill cleanly through tile, simply tap a pointed punch where you're going to drill (to keep the bit from skipping) and drill through it with a masonry bit slightly larger than the lag bolt.
Measure over from a corner to find the 16" stud centers, or use a magnetic stud finder.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 12-03-2007, 08:18 PM   #7
Custom Cabinet Maker
shpigford, IF we presume at least half *ssed installers, open the adjacent cabinets and find the screws holding them, you can figure your 16" centers from them.
skymaster is offline   Reply With Quote
Wall mount toilet warnerww Plumbing 3 07-04-2011 09:01 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
How to mount cables on masonry wall without conduits? dave.murphy Electrical 5 01-24-2007 05:19 PM
