Microwave Turning On Central Air!!? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-19-2007, 05:15 PM   #1
Microwave turning on Central Air!!?
Recently replaced the microwave over the stove c/w hood fan. Fan comes on every time microwave is turned on and, if thermostat setting is below ambient temp, central air kicks in. Can anyone explain to me the mechanism that is happening here. As far as I can tell, the microwave is plugged into an outlet, so no wiring associated with thermostat. Is there a trigger in the ventilation baffle for the microwave that automatically kicks in the vent fan which is then triggering the A/C unit? I'm a DIY rookie, so appreciate any explanation...cheers,
Sean F is offline   Reply With Quote
Old 05-23-2007, 10:44 AM   #2
Rewards Points: 530
First time using the outlet the microwave is on now since the h/a was installed or worked on? If the fan, microwave and central unit are madeup in the same box in the ceilig, you need to get someone to check the wiring out. Sounds like they are all tied together in a way that is supplying power ( completing a circuit)to all three when one is on.
white paint turning yellow victor Painting 40 11-13-2012 09:09 PM
re-routing central vac pipe-how to attach elbow piece yummy mummy Building & Construction 3 12-02-2008 11:58 AM
Microwave turning on Central Air!!? Sean F HVAC 7 06-21-2007 08:15 AM
Installing Central Air using existing heat ducts lvlacic HVAC 2 06-25-2005 12:47 AM
