Microwave Interior Light Stays On And Doesn't Work - Appliances - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 08:12 AM   #1
Microwave interior light stays on and doesn't work
My microwave interior light stays on even when the door is securely closed but you are unable to use microwave. The buttons just beep when programmed. What can cause this?
ritab09 is offline   Reply With Quote
Old 05-04-2013, 09:28 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 1,212
Sounds like maybe the door switch is bad.
Can you program a cook time? But it won't let yo start? If so, door switch. If you can't program a time....start shopping for a new microwave.
ddawg16 is online now   Reply With Quote
Old 05-04-2013, 02:56 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ddawg16 View Post
Sounds like maybe the door switch is bad (or whacked out of alignment).
^^What he said. Link to pictures HERE
Old 05-06-2013, 12:55 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
door switch, but I see no reason to replace the entire microwave for a $10 micro switch
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-06-2013, 01:25 PM   #5
JOATMON
ddawg16's Avatar
Can you program a cook time? But it won't let you start? If so, door switch. If you can't program a time....start shopping for a new microwave.
It helps to read ALL of the post....
I'll translate....if you can't program the microwave, then most likely an issue with the control board. In which case, it's most likely cheaper to just buy a new microwave.
Old 05-06-2013, 01:35 PM   #6
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
I love my Emerson MW with it's mechanical timer, NO electronic buttons, I bought it new in 1987 and it works perfectly, even the original bulb is still in it and works
The problem sounds like the door switch, and if the switch has a safety interlock circuit (such as washing machine lids have) it will "tell" the brain that the door is not CLOSED properly, and as a result I would imagine it will not allow the MW to start. I vote for the possibility it is the switch.
RWolff is offline   Reply With Quote
Old 05-06-2013, 03:19 PM   #7
JOATMON
ddawg16's Avatar
I think any more comments on our part is a waste of time.....the OP has not been back since posting the question...so they have either fixed the problem or bought a new one.
