Microwave Has Exhaust, Vents Inside - Appliances - DIY Chatroom Home Improvement Forum
Old 04-23-2013, 01:07 AM   #1
Rewards Points: 12
Microwave has exhaust, vents inside
I was pleased to see in our new home that the microwave blower has an exhaust line that goes to an outdoor vent. When we turned on the fan for the first time it just blows air out of the ports over the microwave. I can clearly see the vent on the outside of the house and where it connects to the top of the microwave.
I know all of our appliances were replaced two years ago. Would this have been an installation error? Can this be easily changed to vent outside? I'd hate to tear down the microwave to poke around in our new kitchen unless I know what I'm looking for.
vect0r is offline   Reply With Quote
Old 04-23-2013, 01:36 AM   #2
Rewards Points: 192
There should be a diverter on the back of the microwave hood to select recirculate or outside vent. You may have to take the microwave down to access it though.
Rick
bcgfdc3 is offline   Reply With Quote
The Following User Says Thank You to bcgfdc3 For This Useful Post:
PaliBob (04-23-2013)
Old 04-23-2013, 08:17 AM   #3
Rewards Points: 3,130
When you pull the microwave (and I'm certain you'll need to to fix this), get somebody to help you. I've installed and removed a few; they are surprisingly heavy.
Old 04-23-2013, 08:37 AM   #4
Love for Construction
<*(((><'s Avatar
On most over the range microwaves (I installed my fair share) there is two ways the squirrel cage fan motor can be installed for vent direction. Sorry to say but you will have to take it down and rotate the fan assembly for exterior wall vent application. I would look up the model number and get the installation manual and it will detail it out for you.
-luke-
<*(((>< is offline   Reply With Quote
Old 04-23-2013, 02:54 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
installation error. Pull the microwave, remove two screws from the blower housing and rotate the housing 1/4 turn.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-25-2013, 12:57 AM   #6
Rewards Points: 12
I've never had to pull down a microwave before. Is that a pretty quick project? I'd hate to pull it down then spend forever trying to get it back up.
Old 04-25-2013, 04:21 AM   #7
DIY staff
Rewards Points: 7,174
Look up the manual---most have a wall plate with hooks---and then two screws in the cabinet above.
What the screws are removed the unit will fall out of the hole----so have someone hold up the machine while another removes the screws---
If you don't there is a good chance the unit will fall---
Old 05-07-2013, 04:55 PM   #8
Rewards Points: 88
So if air is coming from the top grille when I turn on the vent fan that means my exhaust system is not connected to the outside, correct? Also how often should I change the charcoal filter?
shovad is offline   Reply With Quote
Old 05-11-2013, 03:46 PM   #9
Oso954's Avatar
Rewards Points: 1,114
GE recommends 6-12 months on most of theirs.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
shovad (05-11-2013)
Have Gable/Soffit Vents Contractor Suggest Ridge Vents sallygump50 Roofing/Siding 3 05-11-2012 10:56 AM
Bathroom exhaust exterior wall vents davekirkendall Building & Construction 15 02-18-2011 05:08 PM
Gray (Electrical Conduit)PVC for %95 Furnace Intake and Exhaust Vents? mysterylectric HVAC 6 12-07-2010 08:44 AM
Dryer exhaust duct not connected inside dryer frankrizzo Appliances 4 02-09-2010 08:47 PM
Light inside microwave dakotadog Electrical 5 01-11-2010 06:10 PM
