Microwave - Appliances - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 03:51 PM   #1
microwave
can you install a large microwave with just thew plate on the back of the unit.
coynena is offline   Reply With Quote
Old 05-28-2013, 04:56 PM   #2
Rewards Points: 13,256
If your talking about an over a range micoway then NO way.
All the weights on the front and must be through bolted through a cabinet from above. It takes two peope just to install one there so heavy.
Old 05-29-2013, 02:18 PM   #3
Question
over the stove microwave install
The cabinet seems to weak to hold the microwave.
Old 05-29-2013, 02:59 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
absolutely not. your cabinet may be weak but it doesn't need to support much of the weight, the back wall bracket does most of the load carrying
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
coynena (05-30-2013)
Replacing old hood with over-the-range microwave Nathan0115 Electrical 21 07-27-2012 04:37 PM
Replacing a OTR Microwave that Vents Outside lydiainflorida Appliances 1 03-29-2012 03:03 PM
over-the-range microwave problem aumanpj Appliances 6 12-04-2010 06:46 PM
Microwave ground prong sparks/melts upon plugging it in microwaveman Electrical 30 05-10-2009 11:30 PM
OTR Microwave installation bfarber Appliances 3 12-22-2008 08:55 PM
