Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-19-2008, 03:33 PM   #1
Microhood vent location, diameter, duct type?
I ordered this item model #80823. I do not have it yet but I want to be prepared for it.
Can I use Class 1 HVAC flex duct or do I need to use something more like what is users for dryer vent?
What the diameter is?
Can I vent out the back? If I go up I am going to run through cabinet space and waste it.
Can I share an exhaust port with a bathroom vent by putting a "Y" on it? I.e. Ducts run from bathroom and kitchen separately but there would be a "Y" adapter directly before exiting the house.
Thanks.
pcampbell is offline   Reply With Quote
Old 03-19-2008, 04:51 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a professional builder, just a long-time DIYer. Until one comes along, here is my 2 cents opinion.
If it were me, I would use straight dryer type vent pipe because you will be exhausting cooktop air with grease fumes in it from time to time which may cling to the flex ridges and buildup over time, even though most of it is filtered out.
The vents of these units are usually out of the top. It can be 90ed to the rear from there (out an exterior wall from in the cabinet above), or taken straight up through the cabinets through the roof. A dedicated electrical receptacle will need to be in the cabinet base above the microwave/vent unit. A 15 amp circuit with 14/2-with-ground wiring is probably all that is required by your local code, but if you're running it new, I would run a 20 amp circuit with 12/2wg.
Do NOT try to share a bathroom and a kitchen vent. I had a homeowner DIY one like that once (I'm a Realtor), and he had to have it separated. There were kitchen odors blowing into the bathroom and bathroom odors blowing into the kitchen from that rig. LOL Keep the venting separate.
Also, make sure that the mounting bracket has at least one lag bolt in a stud behind the unit.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 03-19-2008, 07:46 PM   #3
Great point on separating the vents. It is not a big deal and sounds like it's worth it.
We'll be running a dedicated 20 amp run for the microwave. This one has one of these fancy "Convection" oven features. I think that means you can actually cook things in it. Thought it would be helpful around the holidays.
I should have checked on the vent termination point. It will be a shame to give up valuable cabinet space for the vent.
Old 03-19-2008, 10:05 PM   #4
Electrician
Thanks.
Why dont you download the installation instructions and follow them on what they require for ducting?
chris75 is offline   Reply With Quote
Old 03-19-2008, 10:19 PM   #5
Custom Cabinet Maker
model number is fine but whose model number? :} also most are setup for either thru wall or vertical. If you go vertical all ya need do is stay to the back of cab and make a box cover, removable if ya have to get back at it.
skymaster is offline   Reply With Quote
Old 03-20-2008, 02:48 PM   #6
Oops... Kenmore. Chris: I couldn't find the install manual PDF or anything for it.
Old 03-20-2008, 07:07 PM   #7
pc thanx Ok Kenmore and Whirlpool are same same. A manual should only be a phonecall away from either Sears parts or Whirlpool.
Vent location for bathroom exhaust fan slapdash Remodeling 5 06-26-2012 11:38 AM
HVAC return vent location question fatboy HVAC 1 03-10-2008 09:56 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 03:33 PM
Central Air return duct location backpacker2 HVAC 3 05-28-2007 11:07 AM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
