Maytag Washer Won't Work - Appliances - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 09:33 AM   #1
Maytag motor problems
I have an old top-load Maytag washer that's making a lot of thumping noise. I initially thought that the drum might be imbalanced so I rearranged the clothes that were in the drum. That didn't work, so I tried taking out some of the clothes. That didn't work either.
I removed the front panel to see what was going on in there.
I saw the motor move back and forth. Not sure if it's supposed to do that, considering I am a novice DIYer. I'm pretty sure that's the reason why my washer makes all that noise.
Can somebody help me diagnose the problem and tell me how to fix it?
-Paulo
nuclearjesus is offline   Reply With Quote
The Following User Says Thank You to nuclearjesus For This Useful Post:
ed lee (01-30-2011)
Old 04-16-2010, 08:23 AM   #2
it's supposed to slip back and fourth. that's how they clutch the trans. either the belts are bad or the snubber pads [under the trans are shot]. the belts will cause noise the pads will cause the tub to go out of balance.
Jacques is offline   Reply With Quote
Old 04-16-2010, 09:32 AM   #3
The agitator works without making a sound, it's just when the tub starts to spin is when the loud banging noise happens.
Old 04-16-2010, 03:05 PM   #4
Okay.
I replaced the drive belt. It worked perfectly fine when I tested the washer on the last spin cycle.
I put a load of clothes in, and the tub filled up with water fine.
Now it won't do a damn thing. The control board was making a bunch of clicking noises, but now there's nothing. I checked the fuse and that's fine.
I reset my breaker, and still there's nothing with the washer.
Old 04-16-2010, 05:19 PM   #5
Maytag Washer won't work
My Maytag washing machine won't work.
I replaced the drive-belt and tested it on the spin cycle. It worked perfectly fine. I then put a load of clothes in, turned it on, and the tub filled with water. Now it won't agitate, or do anything. I tried putting the timer on different modes, and tried playing around with the different settings. I removed the clothes from the washer, but still, the washer doesn't do anything.
If anyone can help me, that would be much appreciated.
Old 04-19-2010, 10:16 AM   #6
what's your model#? sounds like lid sw or o/balance lever. depending on model.
Old 04-19-2010, 11:32 AM   #7
I got the damn thing to work now.
The tub fills up with water, and it goes through the wash cycle while it agitates just fine.
Now, the problem is that the motor starts to smoke when it goes through the spin cycle.
I'm thinking maybe the drive belt is too short. Not too sure what to do. I spoke with an appliance shop and the gentleman said that I have major problems and that it could be the brake clutch assembly, and that I should just buy a used washer because it would be less than if I were to buy all the parts needed to fix it.
Help!
Old 04-24-2010, 08:17 AM   #8
Rewards Points: 530
Originally Posted by nuclearjesus View Post
Okay.
Did you replace the belt with the belt that model calls for? You can't put just any belt on it just because the lemgth is the same. Automotive belts or table saw belts for instance. Needs to be a Maytag belt if it is a Maytag washer.
handling unsafe work by an electrician wuxingming57 Electrical 1 11-14-2009 07:07 PM
Duct work in garage. flashme18 HVAC 1 11-08-2009 06:29 PM
Maytag washer bearing change Manicmech Appliances 3 10-07-2009 04:12 AM
Maytag WASHER / GE DRYER CAPACITY ?? Chemist1961 Appliances 5 08-26-2009 08:34 AM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
