Maytag Washer Won't Spin, Belt Is Burning - Appliances - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 05:37 PM   #1
maytag washer won't spin, belt is burning
My washer wouldn't spin and was making screeching noise, I replaced the belt and it was still very loud, it ran through the spin cylce once but now wont work again. I can smell burnt rubber when it tried to run. It is a maytag 5000aww about 10 yrs old.
jjenkinsAk is offline   Reply With Quote
Old 08-02-2011, 08:06 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 768
Our last Maytag did the same thing, I tightened the spring up on the motor that puts tension on the belt and it solved the problem. That may be worth a try.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 08-04-2011, 08:53 AM   #3
Rewards Points: 562
make sure all bearings and idler bearings are good. Are the pulleys the belt runs in cupped so belt runs too low and bottoms out,,,check that
4just1don is offline   Reply With Quote
Maytag washer is leaking during spin cycle AngieP Appliances 6 05-27-2011 12:40 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 12:39 AM
Washer: Loose belt - won't spin Hemingway Appliances 5 06-06-2009 05:35 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
