Maytag washer won't drain/spin
Maytag washer, model LAT2300AAE... spin cycle has been degrading (didn't stop working altogether until last night). Got it to spin by moving the dial one click past the start of the spin cycle, worked for a day, now won't spin at all using regular cycle. Started using perm press cycle, after a while the same symptom, now won't drain/spin on any cycle (regular, perm press, delicate). Also, just last night it seems the cold water valve didn't open. Are all these symptoms indicative of the timer module? It's not the lid switch as the washer does agitate.
