Maytag Washer Stuck On Hot - Appliances - DIY Chatroom Home Improvement Forum
Old 04-24-2011, 04:14 PM   #1
First time homeowner
Maytag washer stuck on hot
We just bought a house and it came with the appliances. It has a Maytag washer (unsure of the model, I could look it up if it's important). No matter what the temp setting is, the water is hot. I unhooked the cold line and there is water pressure there. When it's on in any temp setting, I can turn the cold water off with no change in fill pressure. However, if I turn the hot water off, it stops filling.
Any ideas on what could be wrong? Thanks
KaiGywer is offline   Reply With Quote
Old 04-24-2011, 07:35 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
make sure the hot and cold hoses are connected right at the washer ( hot hose to hot, cold hose to cold) if that is correct then you will need to replace the water valve.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 12:37 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Maytag Dishwasher stuck on rinse-only mode - mdbtt60awq WaldenL Appliances 2 06-22-2010 10:46 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
