Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 06-28-2008, 07:03 PM   #1
Question
Maytag Washer Spins intermittenltly.
Our Maytag Washer Mod: LSW9700PQ0 (direct drive) everything works o.k. except many times I could hear motor turning in spin cycle but drum doesn't and if I turn the drum a little with my hand and put lid down then I can feel drum turning, I hope it is not transmission.Pl. help-thanks.
matrcor is offline   Reply With Quote
Old 06-28-2008, 08:34 PM   #2
jeff1's Avatar
Hi,
Timer not causing a pause, bad tranny, loose/worn tub drive block are common trouble makers for intermittant spins.
Something that may help...
http://www.applianceaid.com/direct-nospin.html
http://www.applianceaid.com/direct.html#basic
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 06-29-2008, 10:14 AM   #3
Originally Posted by jeff1 View Post
Hi,
jeff.
Thanks Jeff I will explore above links.
Old 06-29-2008, 03:22 PM   #4
jeff1's Avatar
Your welcome
jeff.
JRAppliance
Old 07-04-2008, 10:08 PM   #5
Jeff thanks again for your help,explored those links, found bad clutch, replaced it and works every time.
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
maytag washer Billie Marcotte Appliances 1 05-21-2008 11:38 AM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
