Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 11-28-2012, 12:38 PM   #1
Branden's Avatar
Maytag Washer Seizes Up
I have a Maytag Centennial Washer, about 3.5 years old. Here is the issue:
I start the washer and it seems to be doing fine. About 1/3 the way through the cycle before rinsing, the washer seizes up full of water. You can hear it buzzing like it is trying to work, but it will not. It will eventually shut down completely (no buzzing). Moving the dial to different parts of the wash cycle (spin, rinse, regular, etc) and pulling it to start will get the washer to kick like it tries to start but will not and just buzzes. If I screw around with it for a while and keep going back to spin and pulling the button to start, i can get the water to pump out and get the thing spinning. But the clothes werent washed completely or rinsed.
So my wife and I are expecting and recently before this started happening, she was washing the newborn baby clothes (which are tiny). Came out missing a baby sock and glove once the load was done. I pulled the agitator thinking that something may have gotten up there and stuck, but didnt see anything. Could one of these things have made it through the drainage holes? If so, I guess this could be the problem.
Anybody have any idea of what the problem can be? Called Maytag and I came to the conclusion that I am either going to fix it myself or buy a new washer. No point in paying $150+ for a repair, I'd rather buy another one if i can't fix it.
Have a great day
Branden is offline   Reply With Quote
Old 11-29-2012, 08:58 AM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
my only suggestion would be to pull the pump and see if the sock is down iside there somewheres, if it is it would make the pump jam up and the washer would pretty much stop
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
Branden (11-29-2012)
Old 11-29-2012, 06:44 PM   #3
Branden's Avatar
Well it was a baby sock. No clue how it got through but it did. Problem is solved
Have a great day
Maytag washer won't drain/spin Wayno326 Appliances 5 06-08-2012 08:31 PM
Air injector broken -- Maytag topload washer TryHard Plumbing 16 01-13-2012 12:23 AM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 01:37 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 04:22 PM
