Maytag Washer Repair - Appliances - DIY Chatroom Home Improvement Forum
Old 12-31-2010, 12:25 AM   #1
Maytag Washer repair
I have a Maytag washing machine that I put new belts on, but it still won't agitate. The spin cycle works okay, and I think the timer is working correctly; but it will not agitate during the wash cycle.
It is a 22 year old Maytag a105 Series 10 machine
tom wells is offline   Reply With Quote
Old 12-31-2010, 12:08 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
with the front of the machine off, put it into the wash cycle, gently pull back on the motor slightly. If it starts to agitate, then you have thick grease in the transmisiion. If it does not, then you have a bad transmission. Either way your looking at a pretty pricey repair. I should mention that if you are in a cold climate and your machine is not warm, it can act like that also because the grease gets very thick and will not agitate. If that is the case all you need is a little more heat in the area.
hardwareman is offline   Reply With Quote
Old 01-01-2011, 07:58 AM   #3
What's it do? fills with water and then stops-dead?-timer? or you hear it running but no agitation?-stripped agt?
Jacques is offline   Reply With Quote
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Maytag washer repair leonidasstugatz Electrical 0 08-10-2010 12:51 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
