Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-24-2008, 08:20 AM   #1
the Musigician
DangerMouse's Avatar
maytag washer not spinning dry...(sometimes)
our maytag washer has been acting up lately. no/not enough spin on some loads. i've checked everything i can think of, and i THINK i have the problem figured out. it seems when i wiggle the motor, it'll kick in and spin ok. anyone else think i need a new belt? it got old and loose? (6 yrs)
it's all i can think of at this point. anyone?
DM
Old 10-25-2008, 02:38 AM   #2
I wouldn't call a 6 year old drive belt on a Maytag top loader "old".
I have three pair of commercial Maytag washers and dryers and all three pair have been using the same pair of drive and pump belts on the washers since 1994. The only difference between commercial and domestic Maytag washers is that the commercial ones have a coin slot to accept money and a place to store it. Beyond that, the residential Maytag top loading washers are the same as their commercial counterparts.
I'd lift the lid and take the tub cover out of the washer and look for some clothing or something caught between the inner and outer tubs.
I'd be very surprised if it turned out to be the belt.
Nestor_Kelebay is offline   Reply With Quote
Old 10-25-2008, 08:06 AM   #3
the Musigician
i've taken the tub out, nothing between tubs... it spins like mad when i try it, as if nothing is wrong. stops on a dime, so brake is fine. i'm stumped... downloading a service manual now, hoping it'll give me an answer. (dialup sux)
DM
Old 10-25-2008, 08:54 AM   #4
the Musigician
well, their troubleshooting chart seems to agree with me....
other forums seem to agree too. i will get a new belt and hope.... anything more and i'll just go get a new washer.
DM
Old 10-25-2008, 10:38 AM   #5
Man of many hats
wrangler's Avatar
If wiggling the motor makes it 'kick in" then it does not sound like the belt, but maybe the clutch.
Man of many hats
wrangler is offline   Reply With Quote
Old 10-25-2008, 10:50 AM   #6
the Musigician
i have some belt dressing in the shed, will try that next. the belt came off easily and looks worn, but not all cracked. all signs still point to slipping belt it seems to me.
DM
Old 10-25-2008, 12:16 PM   #7
the Musigician
welp, that did it.... for how long, idunno. the belt is pretty worn though, probably from all the oversized/unbalanced loads. lol
it ran the full cycle like a champ, though i think i'll order up a belt soon, just to have on hand. i did see a few minor cracks.
DM
Old 10-27-2008, 10:26 AM   #8
DM
If you have a level, you might want to try leveling out your washer. That may help with the unbalanced loads and allow your washing machine to run easier.
TheOak is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
GE washer - spinning cycle does not work proofer Appliances 7 08-26-2008 04:14 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 05:03 PM
Maytag Washer Spins intermittenltly. matrcor Appliances 4 07-04-2008 10:08 PM
maytag washer Billie Marcotte Appliances 1 05-21-2008 11:38 AM
