Maytag Washer Is Leaking During Spin Cycle - Appliances - DIY Chatroom Home Improvement Forum
Old 05-21-2011, 08:36 PM   #1
Maytag washer is leaking during spin cycle
What could be causing my maytag washing machine to leak (very slightly) during the spin cycle. The front is off and when the tub spins, you can feel water being spit out from underneath the tub
AngieP is offline   Reply With Quote
Old 05-21-2011, 09:35 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
sounds like the tub seal is starting to leak. It will get much worse. Your looking at about a $200.00 repair.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-22-2011, 11:31 AM   #3
Both my husband and I are relatively handy. Is this a repair that we could do ourselves with some internet instruction?
or are we asking for trouble?
Old 05-22-2011, 11:54 AM   #4
Rewards Points: 252
If it only leaks during the spin cycle, then I would check the drain hoses and the drain circuit. Look for cracked hoses and the tubing where the hoses connect and clamp.
Marty1Mc is offline   Reply With Quote
Old 05-22-2011, 04:28 PM   #5
#1 HAWKEYE FAN
not really an easy repair, a few specialty tools are required also. First lets make sure it is the tub seal. Take off the front panel and look at the underside of the wash tub, right in the middle where the transmission goes into the tub you will find the tub seal. Run the machine to see if the water is dripping down from that seal. Generally the larger the load the more it will leak.
Old 05-27-2011, 12:32 PM   #6
Thanks for the advice. It was the tub seal and we were able to do the repair ourselves. We purchased the kit w/the tub seal and the bearings so that is done as well. It cost us $60 vs. $200+
It took approx 3 hrs from tear down to repair then putting it back together but it was worth it!
Again, thank you.
Old 05-27-2011, 12:40 PM   #7
#1 HAWKEYE FAN
Good job
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
washer leaking during spin cycle Axle Foley Plumbing 1 11-04-2010 05:25 AM
GE Washer vibrates like crazy in Spin Cycle medicpg Appliances 12 04-19-2010 11:36 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 01:10 PM
