Maytag Washer LAT2300AAE - Appliances - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 04:27 PM   #1
I have an LAT2300AAE Maytag top loader washer that has begun to leak water and the agitation seems to come and go (different noises) during the wash cycle.
I have checked the belts, seem to be okay, I have the front panel off and see no real evidence of water leaking from a specific area. I do notice some small amount of water/grease coming from the bottom of the wash tub, evidenced by the splatter marks around the inside of the cabinet, and it hitting my face while watching a cycle. This comes from the seal area where the transmission shaft enters the tub.
The agitation seems to be okay with a small load but as the load increases the agitation tapers off to a slower speed, as the sound the washer, changes. Agian the belts look okay, I don't see clutch dust as I have on other machines in the past.
Lee C is offline   Reply With Quote
Old 12-19-2011, 08:03 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
the water leak would be from the tub seal, you'll have to replace. Not a real DIYer project unless you are very handy, also a few specialty tools required. Slow agitation could be a number of things, not enough pressure on the drive belt, transmission grease may be getting very thick. Maybe time to talk to a repair tech and have them give you an estimate.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-20-2011, 05:30 AM   #3
Yeah, better off getting a local guy to fix [not rocket science but if not done exactly right-like heart transplants-it'll fail again. pricey repair but there's nothing on the market today-maybe Speed Queen-that compares. if it's not showing any rust this washer can easily go 30 yrs.
Jacques is offline   Reply With Quote
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
10+ Maytag washer oil leak. LAT2300AAE rebar Appliances 5 05-31-2011 02:18 PM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 12:37 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
