Maytag Washer Issue - Appliances - DIY Chatroom Home Improvement Forum
Old 02-08-2011, 05:37 PM   #1
maytag washer issue
This is an older model maytag A5000 top loading washing machine. After washing a load of clothes, the washer tub fills up with clean water. It happens slowly overnight, even after i shut off the water valve to the machine and unplug it. I have to run the spin cycle again to remove the water. If i do nothing, it continues to fill up with a good amount of clean water - almost halfway . What is the cause?
wannabdiy is offline   Reply With Quote
Old 02-08-2011, 06:27 PM   #2
Rewards Points: 530
Are you turning both faucets off??
Old 02-08-2011, 08:18 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
water seepage through the fill valve, change the valve part #205613. You are either not turning the faucets off completly or they are not turning off.
hardwareman is offline   Reply With Quote
Old 02-08-2011, 09:27 PM   #4
The water valves don't feel loose when I turn them. I am sure I am closing both off when i turn the valves. Approx how much does a fill valve cost? Can a novice like me replace it myself?
Old 02-08-2011, 10:48 PM   #5
#1 HAWKEYE FAN
about $25.00/ fairly easy job
Old 02-09-2011, 09:53 PM   #6
thanks hardwareman for the info. i will look into it and go to sears for the part.
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 12:37 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
