Maytag Washer Drum Very Tight. - Appliances - DIY Chatroom Home Improvement Forum
Old 05-05-2012, 10:20 PM   #1
Rewards Points: 107
Maytag washer drum very tight.
Maytag MAV6300AW washer. I had a pipe break in the house and it ran for 2 weeks. There never was standing water in the house but carpet was soaked and extreme humidity. Just got house put back together and hooked up washer today. All seemed fine until I realized the drum was not turning. It is not locked solid, I can move it about an inch in either direction. The agitator works, does that mean the motor is ok or does it not run the agitator? Any ideas what could have happened, I am assuming it has to do with the humidity?
thunderhead is offline   Reply With Quote
Old 05-06-2012, 12:37 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,598
so what are you saying? no spin ? if you are trying to turn the drum by hand, its not going to happen
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-06-2012, 01:27 PM   #3
Rewards Points: 107
Yes, it does not spin. I can spin my old Hot point very easy but it is 30 yrs old.
Old 05-06-2012, 04:41 PM   #4
#1 HAWKEYE FAN
the brake probably swelled up from the moisture, may just need more time to dry out.
The Following User Says Thank You to hardwareman For This Useful Post:
thunderhead (05-06-2012)
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 08:47 PM
maytag top load washer not spinning at times ed lee Electrical 2 01-07-2011 01:37 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
LG Washer not putting water in the drum RuralPrincess47 Appliances 4 07-28-2010 01:50 PM
Maytag Washer Spins intermittenltly. matrcor Appliances 4 07-04-2008 10:08 PM
