Maytag Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 11-04-2012, 02:09 PM   #1
Angry
Maytag washer
My Maytag washer will not fill with cold water. The hot water fills though.
bthib42 is offline   Reply With Quote
Old 11-04-2012, 02:19 PM   #2
Rewards Points: 14,312
No model number?
Did you disconnect the hose and check the screen in the hose?
Make sure there water coming out of the hose while it's disconnected from the washer?
Checked with a multi meter to see if there's power going to the coil on the fill valve?
Old 11-04-2012, 04:11 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
water valve most likely bad
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
Maytag washer drum very tight. thunderhead Appliances 3 05-06-2012 03:41 PM
10+ Maytag washer oil leak. LAT2300AAE rebar Appliances 5 05-31-2011 02:18 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
