Maytag Washer - Appliances - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 05:55 PM   #1
maytag washer
on the spin cycle it acts like the tub is hitting the body on the right side. level shows machine to be level. it was recently moved and was laid down. what should i look for?
kjohome@hotmail is offline   Reply With Quote
Old 10-08-2011, 10:34 PM   #2
Front load? I had one that had the mounting arms broken from moving it. Not sure the technical terms but it was the parts that supported the drum and had the shocks/struts.
Wasn't cheap to fix; if I remember the labor was the expensive part...
Justgaff is offline   Reply With Quote
Air injector broken -- Maytag topload washer TryHard Plumbing 18 07-17-2015 07:47 PM
maytag washer makes banging noise atechdrew Appliances 1 04-25-2011 08:38 PM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 01:01 PM
Maytag Washer and GFI mwarken Appliances 3 12-09-2008 03:22 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
