Maytag Wash Machine Leak - Appliances - DIY Chatroom Home Improvement Forum
Old 10-17-2011, 07:03 PM   #1
Maytag wash machine leak
My wash machine just sprung a sudden and major leak. It's coming from
inside the washer, not from an attached hose. There are several drain holes in the bottom of the machine where the water is coming out.
The model is MAH6500AWW. I'm not sure how old it is, but no more than about ten years.
Any suggestions would be appreciated.
Jean Pete is offline   Reply With Quote
Old 10-17-2011, 09:23 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
did you even take the front off to look inside, if not how can we help?
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 10-17-2011, 10:50 PM   #3
It's a front load machine, but I agree - will try to open it up.
Old 10-18-2011, 09:02 AM   #4
#1 HAWKEYE FAN
I know it is a front load machine. The front comes off with the removal of 4 screws. If it is leaking that bad it should be very obvious when you open it up. Probably the tub to pump hose has a hole.
Old 10-18-2011, 10:25 PM   #5
Wow - this seems surprisingly easy. You're right, it was easy to take off the door. Once I got it off, the problem is obvious. The small black tubing had come apart, and I could easily put back in place, as shown in the pictures. There's a green clip on there that doesn't seem to be doing anything. I'm thinking of just taping over the fitting to hold it in place.
Old 10-18-2011, 10:34 PM   #6
Its quite easy to repair washing machines. I do the repair on our machine too. You just have to have the guts on trying it yourself but not the wirings. I know nothing about electrical matters. That i will leave to the electricians...
we were born to succeed, not to fail
jcsites is offline   Reply With Quote
Old 10-19-2011, 08:04 AM   #7
You don't have it in far enough. the collar on hose fits into the collar on bellows- then put the clamp on.... if that hose is all slimey and deteriorating you might want to replace it.
Jacques is offline   Reply With Quote
Old 10-19-2011, 10:39 AM   #8
Rewards Points: 6,652
Who ever installed the hose, did not pull the clip over. If it does not hold it, get a screw down hose clamp to replace that spring clip. Fernco's work wonders also.
Old 10-19-2011, 07:42 PM   #9
I agree, I don't think the clip was ever on there right. Got it resolved and am running my first load now. Picture is attached, with the hose pushed on much further and the clamp now over the joint area.
I truly believed I would have to get a new machine. Thanks for the advice!!!
Old 10-19-2011, 08:43 PM   #10
#1 HAWKEYE FAN
that is exactly right, congrats on your first Neptune washer repair
wash machine hose repacement boblo Appliances 1 06-09-2011 06:15 AM
10+ Maytag washer oil leak. LAT2300AAE rebar Appliances 5 05-31-2011 03:18 PM
Maytag MBF2256KEQ Refrigerator Leak FYI StahlMaster Appliances 0 03-07-2011 12:19 PM
Water Leak in Maytag LA511,,, jjjoooggg Appliances 1 04-10-2010 11:32 AM
Vent for Wash Machine tuchodi Plumbing 2 12-20-2009 11:37 AM
